besoin d'aide pour choisir des pieces poue face monte carlo
hello
j'ai besoin de vous , je sais pas quoi choisir pour ma monte carlo que je transforme en SS
il me manque les partie qui partent du support du radiateur et qui vont se fixer sur le bumper
pouvez vous m'aidez , je sais pas quoi prendre
http://www.dixiemontecarlodepot.com/78-88montecarlo_subSections/s20.htm
DM10548
1983-1988 Monte Carlo SS Top Plate COVER with custom bead roll. This is a cover plate for the top plate that is hard to change out. If your plate is holding the nose up, this cover plate is easier to put on and less expensive than changing the factory top plate. You can have a good looking top plate in 5 minutes with this new cover plate. Just remove the four rear bolts and a few of the plastic rivet fasteners, slide the plate in and refasten back down. Works well with DM10547 as well. - New - aftermarket (Made in the USA)
DM10547
1983-1988 Monte Carlo SS Top Plate filler panels with custom bead roll. A great way to dress up your Monte Carlo SS and hide all of the ugly headlight and park light wiring and bumper and absorbers. Cleans up the appearance under the hood. A must for every Monte Carlo SS. (Made in the USA)
DM10546
1983-1988 Monte Carlo SS Top Plate filler panels. A great way to dress up your Monte Carlo SS and hide all of the ugly headlight and park light wiring and bumper and absorbers. Cleans up the appearance under the hood. A must for every Monte Carlo SS. (Made in the USA)
DM10646
1983-1988 Monte Carlo SS Top Plate COVER. This is a cover plate for the top plate that is hard to change out. If your plate is holding the nose up, this cover plate is easier to put on and less expensive than changing the factory top plate. You can have a good looking top plate in 5 minutes with this new cover plate. Just remove the four rear bolts and a few of the plastic rivet fasteners, slide the plate in and refasten back down. Works well with DM10546 as well. - New - aftermarket (Made in the USA)
DM10846
1983-1988 Monte Carlo SS Top Plate. Items are made of thick mild steel and powdercoated satin black. Get rid of that pitted rusty plate and clean up the appearance under the hood. A must for every Monte Carlo SS. Part is of heavier gauge metal than original. (Made in the USA)
DM10746
1983-1988 Monte Carlo SS Top Plate filler panels and center plate combo (DM10546 and DM10846). A great way to dress up your Monte Carlo SS and hide all of the ugly headlight and park light wiring and bumper and absorbers. Also includes a new top plate. These items are made of mild steel and painted satin black. Cleans up the appearance under the hood. A must for every Monte Carlo SS. (Made in the USA)
j'ai l'impression que les modeles sont differents
voici une photo de la mienne
DM10548
DM10547
DM10546
DM10646
DM10846
DM10746
maya.bz- Mordu
- Ville/Région : FRANCE
Nombre de messages : 451
Voiture(s) : Monte Carlo SS 85
Re: besoin d'aide pour choisir des pieces poue face monte carlo
il te manque le cover du milieu qui sert de retenue et de finition pour le pare choc et les autres sonts de couvert esthetique seulement pour remplir l'espace entre le pare choc et le haut du support de radiateur dm 10746 semble etre le kit avec les 3 pieces incluse
merci j'ai trouver
maya.bz- Mordu
» Besoin daide :)
» whells 17 " pour monte carlo
» moteur pour monte carlo 79
» Monte Carlo SS 900$ pour projet , vendeur motivé!
» besoin daide!!
» besoin daide!!
